8inches 38s
Jakest933
North carolina
Jake
Got 38/13/16 an piecing together a 8in lift and crossover steering all spring in front wonder of anyone has similar set up
77 K20
Montana
K20 5" lift
HT383 fuel injected
There are some on here. I'm trying to keep my center of gravity lower, so have a 5" lift and 37s with crossover steering. Quite a bit of fender trimming. Since fenders were rusted it wasn't bad to do.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Move your axle forward with a zero-rate/easy inch spring plate with offset pin. Slide cab back as far as possible , if it has any leeway. Some do.. some don't.
Don't use any spring other than;
Deaver
ORD custom multi pack (Deaver copy)
or Tough Country for budget.
Jakest933
North carolina
Jake
Deaver
Is the ez inch so tire is further away from fender
disenough
Rock Hill SC
brice
Yes it moves the axle foward.
Where in nc are you?
I'm in rock hill.
Jakest933
North carolina
Jake
I'm in rock hill.
Zebulon bout 30 min east of Raleigh an do you happen to know if I can use stock drag link an pitman arm with crossover
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Zebulon! Nice. Im in salisbury.
I had a k5 on 6" of lift with narrow 38" boggers.
Steering was kinda chitty, even with the "drop pitman arm " the kit includes.
To answer that question, crossover steering will require a 2wd gear box. The swing of the pitman arm is different.
A 4x4 gearbox swings parallel to the frame, 2wd swings underneath the frame .
The draglink on a stock truck wont be near long enough, seeing as crossover ties the gearbox over to the passenger side knuckle.
Rumbledawg
the back 40
K30 crewcab
i'm running skyjacker soft-ride 8" springs with cross-over also.
i run 3 diff size tires, 38" swamps, 42" swamps and 38" toyo m/t's, all on 16 incher rims. swamps are kick-a$$ off road, but HORRIBLE on the street. remember back in the day with bias tires how they would be square every morn? wait until ya got square 38's every morning, they will shake the fillings out of your teeth until they warm up and round out. second biggest prob i find wit my swamps is there is no siping.....lots of fun on wet roads, and if your running lockers...double your fun...
if your haul heavy loads wit your truck, i would not bother with rear lift springs. haulin' my camper flattened my rear springs in about 2 yrs, so i use 4" shackle flips wit a 3" block and airbags in the rear with GM H-D 9 leaf packs
Vbb199
Salisbury NC
Vince
Yea, i run 39.5x16x16.5 boggers on my trail truck (1 ton solid axle swapped s10 blazer) lockers front and rear with hydraulic steer, its a beast, but a real teeth beater on the road with those cut and grooved boggers
Garcjay
