89Suburban's Wanted List
Yeah but the factory one won't work. Do you need it? I'm think about using a jack bottle.
Get the 8 dollar universal one from AZ, it should be perfect for that situation. I would not run without an overflow but that's me.
I might have the left turn signal assembly. I won't know though until I get out to my dads and look at my brown trucks to see if one of them survived the fire or the collision. You need the one in the fender, not the grill right???
Can't help with anything else though. I put the only overflow cooling bottle I had to good use and I need a set of pw switches myself for the 85 K1500.
wildcatjason
Kansas
Jason
suburban
cummins 3.9 4bt
It will have an overflow. I just want something cool.
I am VERY DESPERATE for the high beam push rod that runs down the inside of the column if anybody has one laying around unmolested. Mine is bent and I can't get it to work right. :(
Id imagine that would have survived the fire in the burnt truck. But buddy, I don't know how long it'll be before I could get out there to get it. I figured I'd end up trashing that column. I know all the plastic switches and wiring to and in the column is burnt. Anything metal would have survived though. Being encased, maybe not even smoke damaged and if so, probably clean right off.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
****...if it were me, I would re route the wires down to an old school foot switch...fark the rod!
Is this what you are after little buddy?
I also have an over flow bottle, an a few other things on your list.
PM me you addy, I'll try to get it sent today. Do you still need the over flow bottle, and left front turn signal. do you need the whole assembly, or just the lens, cover what ever you want to call it?
****, I just realized you offered me the bottle also. I think I am getting senile.
I'll send PM bro, thanks. I didn't know the lens came off the housing, I thought it was all one piece, so just the lens is fine. Still need the factory overflow bottle. High beam push rod. I can't believe you have one, lol. :)
I am updating my list right now also.
sorry little bro, both of my over flow bottles were ****, one was dry rotted, and the other had a whole in it, that I found once I had it off. But I did find two right, and left turn signals and you were correct they are one piece.
That's ayaate man, I'm humble. :)
PapaBear8486
