'87 TBI 350 Troubles
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Hmmm. have you looked at the injectors while its running? Have someone cycle the key on and off, for the fuel pump to run, with 10 second pauses in between, to see if the injectors are leaking.
Are you sure the timing is set correct with the brown wire off? Possible that the timing chain jumped at all? :shrug:
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
it is at the 2nd notch from the left on the plate that is attatched to the timing cover that shows the timing and i just replaced the timing chain that probably hasnt run for more than an hour
Jims86
Patterson,Ca
5.7 TBI
try turning it a few degrees counter clockwise at a time, and see if it will fire and run on its own. sounds like you may have it too far advanced.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
shouldnt i move it clock wise to retard it? i have already tried it where it was all the way to the right on the tab thats attatched to the timing cover.
Jims86
Patterson,Ca
5.7 TBI
So you do have a timing pointer?I thought you didnt. it should be dead center on 0*
havyou opened up your distributor and made sure the picup coil is in god shape.
Should be set to zero warmed up at normal idle with brown wire unplugged.
attachment.php
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
Thanks 89sub. Thats what i was wondering.
The pickup coil is brand new.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
What would the symptoms be of a bad spark control module? If the ECM was bad the injectors wouldn't be spraying right?
A bad control module would shut the truck down completely. Mine gave signs of it going, started randomly shutting off.
ECM going bad, you really don't see many reports of that. I thought mine was bad and swapped another one in and it was the same.
I would just start off setting the base timing correctly and we can go from there. I am assuming tour emissions/vacuum hose label is missing?
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
Are you talking about the sticker on the radiator support? I'll reset the timing when I get home.
Jims86
Patterson,Ca
5.7 TBI
All TBi small blocks are 0*, 454's are 4*
There are 2 items to worry about for ignition on an 87-92 tbi truck... The Ignition control Module which is in the distributor, and the Electronic Spark Control, which is mounted next to the throttle body....Later models had the ESC in the EProm chip in the computer.
There is a possibility that one, or both are on their way out, but IIRC, you said the timing was advancing off the scale when you plugged the timing wire back in? It is importannt that you check the injectors like I said earlier, just to rule those out, the we can check the ignition components...There is no way to check the ESC, but most good parts stors can test the ICM.
ECM gets pulses to run the injectors from the ICM, and the engine should run with the ESC unplugged, as it is only a knock filter, and sends timing retard commands to the ecm.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
The entire distributor is new including the modules that are with it l
The injector don't do anything when you cycle the furl pumps with the key
I had the distributor timed at 0* and there wasn't a difference; the timing mark was almost vertical at idle and it didn't change smoothly when I gave it throttle.
Jims86
Patterson,Ca
5.7 TBI
With the wire plugged in?
brcarlson75
