86 M1008 LM7 Swap
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I recently picked up an old, tired 1986 M1008. My detective work says the cab and frame are in fact an Army truck but the drivetrain and axles were pillaged over the years. The truck has a Dana 44 front axle, 12-bolt rear axle, a 350 SBC (removed), an SM465 trans, and NP-208 transfer case.
The donor power plant is a mix of an LM7 and an L59. The engine (intake to oilpan) is an 04 LM7. The harness, PCM, tac module, pedal, etc. are from a 2005 flex fuel suburban I found in a local junkyard. My goal is to marry the two together in the truck and get it up and running with the current drivetrain before looking for a 14-bolt, Dana 60, and a more modern manual trans.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
fter cleaning it up and getting conflicting info with two VIN numbers on the truck I am fairy confident it is an M1008 based on the partial VIN on frame, VIN, plaques, and dash support in cab.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Axles, trans, and transfer case.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Tearing down the donor engine.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Looks like a roller lifter gave up the ghost and trashed the cam.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
The block looks good with a minor amount of wear in the cylinders.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
The bearings all looked pretty good as well.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Made my own lift plate from some scrap 3/8" steel plate.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Donor harness, pedal, TAC module, injectors, MAF sensor from a junkyard 2005 Suburban.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
It cleaned up pretty nicely at the machine shop, but I sandblast, pressure wash, and paint later.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Pilot bearing because I don't do automatics. Looking to do the advanced adapters kit to mount my SM465. I've also heard about a Sachs flywheel that will let it mount right up.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
New bearings and a Fel-Pro rering kit.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Starting the reassembly process. I hate the OTC angle dial tool I bought for what it's worth.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Continued.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
Hand lapping valves, rebuilding heads, and installing BTR trunnion upgrade. Who needs a hydraulic press when you have a Harbor Freight vise?
C30vet
