73 C-10 eating fuel pumps alive. HELP!
heffalump
Lafayette ga.
jeremy
2500 suburban
My 73 has recently started to go through fuel pumps at an alarming rate. Today makes number 4 in the last 3-4 months.. Anybody else had this problem or have any ideas? Stock 305 all new rubber clean steel lines new/clean filter and new sending unit with new in tank sock filter. All 4 pumps began leaking out the weep holes in less than a month..
dvdswan
Port Orchard, WA
Dave
What brand? Lifetime warranty? Where were they made?
I've had 2 parts (water pumps) bad out of the box before. It does happen time to time with rebuilt parts.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Yeah I don’t believe it’s anything wrong with the motor, did you clean the tanks out at all? Just crap fuel pumps is my opinion
heffalump
Lafayette ga.
jeremy
2500 suburban
Can't remember the brand. All 4 are the same. Bought from AutoZone and they do have the lifetime warranty so I can just get another one but this will make the 5th on since I've had it.
CSFJ
I think I would try a better brand. Here's all you need to know about an autozone warranty
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
And that right there is discount auto parts/tools/etc in a nutshell. Fantastic! I forgot how spot-on that movie was!
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The AC Delco has a limited lifetime and some of their lower tier product lines have been outsourced to other countries so it might just be a piece of crap with a good name on it. I’d go with the Delphi or even the Spectra. My Delphi has 20,000 miles and counting.
crpntr78
Missouri
Very true about outsourcing. My new AC Delco wiper switch was made in China!:flame:
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
I got one from oreillys 3 years ago and no issues.
Zoomalot
Banned
Parksville
Randy
Silverado Shorty
350 Ram Jet
" NOT all V-8 Chevy mechanical fuel pumps are the same !!!!!!"
I am guessing you have a fuel pump rod length and arm difference issue.
Check your correct part #s again
heffalump
Lafayette ga.
jeremy
2500 suburban
Pump turned out to be a Delphi brand. Swapped it for a new one. I changed the filters and sending unit after I put the previous pump on. The engine in it is supposedly a 305 H.O., truck came factory with a 350. I can't remember if I gave the parts store info on a 305 or 350.
rpcraft
Robert
LS 6.0 364 CID
Is it the original tank?
heffalump
Lafayette ga.
jeremy
2500 suburban
No not the original tank. Tank was salvaged from a 76 step side, so the tank is tiny..
johnalen76
