700R4 Wiring Connections
97350
Canada
Duane
C1500
After working through my tv cable and shifting issues,my transmission is now working fine.The next thing I want to is to connect the four pin plug to the transmission.My question is what does it connect to under the hood?
When I bought the truck everything was disassembled and in the box of the truck.It was obvious that the wiring to the transmission was ripped out when the engine/trams was removed.
I understand that there is a vacuum switch on the dash,but I have one with two green wires to it already.Is there supposed to be a second one?
I should have mentioned that this is an 83 Chev pick up.
MadOgre
NA
NA
NA
NA
NA
Isn't the plug already wired into the trucks wiring system? You should be able to just plug it into the transmission ? No?
When ever I pull a transmission I just unplug that plug and then just set it aside. Did the PO cut it off and leave it on the transmission ?
Obullard74
