6.2 machanical with 4L80E 4x4
Dieselbrent
South carolina
Christopher
Chevy
5.9L Cummins
I'm needing help with a mechanical 6.2 litre diesel and 4L80E to work together. I have a TCU waiting harness for a gas motor just needing help making it shift since there is no tach to tell it when to shift. Any advice would be great.
yevgenievich
Viktor
sad
very sad
less sad
Either add your own cam/crank sensor or look for gm 91-94 2500 trucks with diesel for parts.
CookieSoup
Seattle area
Suburban
or go manual control on the trans
Dieselbrent
South carolina
Christopher
Chevy
5.9L Cummins
What about using Dakota digital guages and the tach kit from Dakota digital for my 6.5 diesel and 4l80e combo
71RAT
Deerfield NH
Kirk
K20 Scottsdale
Your probably better off using a standalone transmission controller. I've used several PCS Simply Shift kits. They work well and user friendly. There are many others on the market, PCS is just what I'm familiar with. If your are trying to use an OEM controller and harnesses it's going to need some modifications. If it's even possible.
Mousta5
