5.5/7 lowering kit left front lower then right front
brascon8
Leadville
Sierra classic
Hello everyone so like the tittle states I recently just lowered the front end with 2” coils and 3” spindles but the left front is 1/2 inch lower then the right and tire scrapes inner wheel well when turning. Only difference ive noticed is that the sway bar bushing on the left front lower control arm is missing. Can that lower it more then the other side? Im lost right now any input greatly appreciated btw its a 84 c10 swb
quarry trash
Hendersonville NC
Brandon
k5
Bushing shouldn't make a difference, with that being said anything is possible. I would start by making sure the coils are totally seated in the bucket on the high side. Next in would make sure my shocks are not binding up at any point. Then from there I would measure the difference in my distance from lower control arm to bump stop mounting point (assuming you have removed the stops). It is totally possible that someone somewhere sent you two different spring rates which would make the difference possible. Hope this helps man
GMC3
Bowmanville, Ontario
Ryan
Did the truck sit level before you put the springs in?
brascon8
Leadville
Sierra classic
Yea I basically took everything apart and compared all the parts everything looked the same springs were seated properly and still same results. Truck wasnt sitting abnormal as far as i remember idk im stuck right now im thinking of getting a spring seat to raise it.
GMC3
Ryan
Wouldn’t surprise me if the truck was already 1/2 lower, I believe I trimmed my springs to get it where I liked it, and if I remember correctly one side I cut more off of
Kipps5000
