5.3 LS Swapped Computer Program
custodian
Catawba
William
5.3 LS, 350
What computer program are those using to reprogram the 5.3 swap?
eskimomann209
Modesto
Marcus
EFI Live HP Tuners
HP Tuners LS1 Edit
I’m sure there are others
RoryH19
Rory
R10 Silverado SWB
What he said. HP tuners
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
i bought an HP Tuner. I use it quite a bit. I just swapped gears in the diff and added electric cooling fans to my 6.0 swap. I've tuned a couple of other vehicles as well. The learning curve is steep in the beginning, but it's worth learning.
Joe
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
HP Tuner. Fortunately I have coworker that is an experienced tuner and has been a big help. You Tube university is great as well. Goat rope garage for example.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I'm trying to learn it as I go but my local tuner is being cryptic and unhelpful. I have an L59 PCM, TAC module, pedal, and harness I would like to put in my 86. I want to use the SM465 but he is bitching about having a VSS for idling. What is the bare minimum that needs to be done to the PCM to get it running? Removing passlock?
Steamtown
NEPA
Jack
R3500
No VSS needed for a good idle anymore. Removing VATS is the minimum to have the engine run.
Madhorn
AR-Arkansas
Ken
You will need a speed sensor. Computer needs to know when vehicle is moving and when it’s not. Dakota digital has what you need. Can’t remember PN at the moment.
lorisa2u
