.460 vs .708 spark plugs in vortec heads
fowjacob
Lubbock,TX
c3500
383 Stroker
I'm asking because I have flat top pistons and don't want to the piston to hit the spark plugs
fowjacob
Lubbock,TX
c3500
383 Stroker
Hmmm....
Whats the primary use of the truck?
Daily driver
But a vortec head calls for a .708 and a stock head calls for a .460 but I have flat top pistons and don't want a hole in my piston if the plug is to long
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Daily driver
If your valves clear, a standard plug should. Pligs usually dont protrude out of the combustion chamber. Did you have the heads milled?
fowjacob
Lubbock,TX
c3500
383 Stroker
no because they were brand new when i put them on
Jims86
Patterson,Ca
5.7 TBI
I think the valves would hit the piston before the plug. Did you put clay on the piston to check clearance before you put the heads on?
fowjacob
Lubbock,TX
c3500
383 Stroker
no i think im just going to go with the .708 plugs sense that what the vortec calls for
forum.73-87chevytrucks.com/smforum/index.php?topic=17803.0
Jims86
Patterson,Ca
5.7 TBI
You shouldnt have a problem. I have not seen stock Vortec plugs protrude passsed the inside combustion chamber surface.
fowjacob
Lubbock,TX
c3500
383 Stroker
Thanks Jim
1low4x4
Nick
Any feedback on this fowjacob?
1984dually
Malin OR
Danny
C30
8.1L
Tried the short plugs in a set and it didn't run very good. Use the plugs for the vortec heads
Green K10
