454 headers?
shanegtr
Perth, Australia
Shane
R2500 Suburban
Just spied a set of 454 headers for sale on one of my local Facebook groups. They look unused and I was thinking about grabbing them as it would save me some $$$ in freight from the US when I get around to putting on a new exhaust into my burb. My question is could they be used for my 89 TBI 454. The seller has advised they where for a C20 with round port heads. My burb is currently stock in the engine department which I'm assuming would be peanut ports. Would there be any issues with that bolting up? Future plans are for better breathing heads, intake and cam but that could be a while off. In the mean time the exhaust does need some attention. Any help appreciated
Most stock big block heads have squarish exhaust outlet ports, but obviously, most headers have round ports at the flange. Just make sure the gaskets that you use will sufficiently seal both the head and the header.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Pre-fit the headers before you actually install them. Any tight points don't be afraid to pound a dent somewhere for clearance. Make sure you can get at all the header bolts and spark plugs. Need room for the socket! Be prepared to reroute your starter wires and possibly the auto coolant lines (if you have an automatic). Re-tighten the bolts often for the first few months of use. Make sure to use proper header bolts for best clearance.
3dbello
