350 OEM swap to a 454 HO
Justin Willey
Justin
TBD
Im going to be buying a 454 HO and a manual trans to put in my K10 and i was wondering are there any recomendations for upgrades to do to the engine before putting it in my truck, and whats a good carb to put on it? I plan on using it for semi-daily and a offroader. and any overall recomendations to upgrade on the truck itself?
Strick
Dunn, NC
Harold
C20 Crew
The 454 isn't going to make fuel or fuel economy so I'd feed it with a healthy carb. If it's the GM 454HO then it should be good for about 500HP. I love Q-jets for daily drivers and off-roading. They are not as sensitive to whoopties and vertical situations like Carter and Holley carbs are. Welcome to the site and show some pics; I've found out this crowd loves those.
Strickland
fast 99
Spokane, Washington
Yes, a q jet has the best combination of fuel economy, drivability and CFM but as previously stated a BB will like fuel. Need to have someone who is familiar with them to get the fuel trim correct.
I would add an O2 sensor to the gauge package no matter what carb you decide on. Most carbs out of the box are too rich.
Justin Willey
Justin
TBD
Strickland
Thanks for the Info
MrHorsepowerLSx
New Jersey
Jeffrey
K35
If you have some room In the budget a Holley sniper efi kit would be great for a hungry big block. Orrrrrrrrrr you could LS swap it and have great power and decent fuel economy in a smaller package. You could still run your trans of choice as well with either route you choose
johnalen76
