3208 cat engine
silverscottsk10
trafalgar indiana
mike
I seen on Facebook someone was going to try to install it into a 79
It looks like it's a bit big for the bay
But if it could fit I wouldn't mind seeing and getting tips due to everyone doing cummins swaps (irritating) I'd like something different
Driver4r
Nebraska
Trevor
k10,c20
If i remember right, the 3208 is what i was looking at putting in a short stepside, But then i read that they were way underpowered for the weight of the engine.
Just so you know.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Nearly 1700 pounds for the smallest one. Also read that 4.5 mpg is the average fuel consumption.
silverscottsk10
trafalgar indiana
mike
It's not gonna be a race truck lol
Just different
And it's only 500 pounds more than a cummins
No biggie right?
Cowboy Cadillac
Grande Prairie, AB, Canada
James
Ive always wanted to do a Detroit 6v71 swap into a CCLB dually. Iirc the injectors are an issue in the 3208.
Green79Scottsdale
G.R. - MI
Bob
Just different
No biggie right?
3208 - 1700 lbs.
Cummins - 1100 lbs.
Small Block - 575 lbs.
I call that biggie...
Driver4r
Nebraska
Trevor
k10,c20
I wanted to put Dual 6" stacks and turn up the pump. Make a little big rig out of a Square Short stepside street-rod.
metal tech
Choctaw OK
Al
84 & 85
K10 x2
305 x2
silverscottsk10
trafalgar indiana
mike
That's sweet metal tech thanks
Man it's a tight fit for sure
It may not fit with my brake booster and cylinder assembly
I'll definitely be talking to a couple of the teachers here on campus about it
And this won't be the first place that don't like my sarcasm lol
metal tech
Choctaw OK
Al
84 & 85
K10 x2
305 x2
take a minute to look at those Detroit 4-53 swaps. That engine is almost the same size as a Cummins 6BT/ISB (Dodge truck). Trying to find something to make your truck unique is a job in itself. I wish you luck no matter what you choose to do.
eatfood
