305 tpi to tbi question
JD02
United States
Cam
K1500
Recently picked up an 87 K10 with a bad tbi 350 in it. There’s a tpi 305 out of a 92 Camaro for sale for cheap in my area.
My question is, will the tbi intake bolt directly into the tpi heads?
TIA
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
If both have Centerline valve covers. It will interchange. I really like the TPI engines myself.
JD02
United States
Cam
K1500
Do you think the ecm would have any issues running the roller cam and head setup?
SquareRoot
The ECMs are not interchangeable, Completely different animals. A TPI ecm from a 305 will need some programming to run a 350 TPI as well.
squaredeal91
Greg bush
1991 SB
@JD02 said] Do you think the ecm would have any issues running the roller cam and head setup?
[/QUOTE]
That I'm not sure of.im sure someone will chime in
bluex
Spartanburg SC
C15
There are several upgrade pcms an harnesses for TPI engines. I'd run it off one of those. The TPI was the best truck intake they never put on a truck!
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Agreed but he's wanting to put a TBI intake in place of the TPI.
It will probably run too rich due to different parameters, but certainly putting a 305 injectors and ECM on it would be fairly easy, might be a sensor or two different but easily found.
Put your tbi manifold on your tpi motor,with 305 injectors ,it will run just fine,the tbi is manifold pressure controlled those heads and cam are not enough to confuse it.
michaelmarine53
