akchevrolet
- Sep 22, 2016
- Texas
- Andrew
- R10
I was wondering the best way to wire the positive wire for tge heated o2 sensor.
I don’t know how much power a oxygen sensor pulls but wouldn’t I engine running power be best or is it turn off after it’s temp/negligible power drawI ran mine off an empty IGN tap in the fuse box. I ran an inline fuse holder just to be safe. It was easier to do that than determine if there was already a fuse that ran that IGN tap.
Yes but how much heat we talking, electric choke lolIt only gets power when the ignition is on, which is how the O2 heater is designed to work. There's no draw when the truck is off.
oh must be insignificant then most newer cars have 4+I don't recall off hand. It's a non-issue though, it's not designed to cycle on and off as needed. Whether or not the engine is running, it doesn't care. It's just designed to be on so that it can get a proper reading without relying on exhaust heat to warm it up.
Burn means you have less mass, less mass is the key to efficiency. Clearly we need our engines to be lean as possible at every stage so we can produce nice clean combustion and wow that is one red catalytic converter, shall we observed the temperature precious metals become liquidI have a heated O2 sensor on my 1978 MG-B, converted to two SU carbs from a single barrel whatever it was carb.
I wanted to be able to monitor the air/fuel ratio without having to pull over every ten miles and pulling plugs. The sensor is hooked to a gauge in the cabin.
Last trip out, right after installing the gauge, got 50 MPG but thought I was going to scorch pistons coming back home from Billings. I dont remember the numbers but it was lean, way beyond comfortable lean. Had to back out of the throttle through the hills to keep it from going to the burn stage.
You can ground it anywhere you want as long as it's a good ground.Ground is indiscriminate ,it all goes back to the battery negative.Do you just ground it to the frame
