- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
In theory, can't I engage the overdrive in any gear? I know that is how it works with a Gear Vendors.
It doesn't really matter though, since if I engaged it in 2nd, it would still be 1.05 to 1, not an overdrive.
Depending on how you set it up, you can run it in OD in any gear except reverse. It's a pain to shift it like that as it requires a lot of switching on and off of the solenoid. I will shift into 2nd, and then depending on the traffic, either switch on the solenoid for 2ndOD, or just go into 3rd and wait until highway speeds are achieved and then switch on the solenoid, let off the gas for it to engage, then hit the gas and cruise with lower rpms.
A Ranger OD in reverse would depend completely on your reverse gear. I doubt you could go highway speeds in reverse without over-revving the engine.
