275/60 or 295/55 rear tire (lowered)
speedy
MS
Brandon
Hey guys need some opinions.
My 82 is lowered 5/7, and that may change if there is an issue. I can raise it 2" so that it will be a 3/5 drop.
Anyway I am looking at getting a set of drag radials. I've been eyeing mickey thompson ET streets. They have 2 sizes I'm considering. 275/60 and 295/55 which is roughly the same height but wider. I'll be running these on a 15x8 wheel (If 295s will work I will eventually get the 15x10 rallys)
I have 275/60s up front now that seems to do ok when I do get her out on the roads. Will I be better off to run the same size in the back or go with the wider 295s and swap to the 15x10s later? Anyone have any experience with this?
Thanks
speedy
MS
Brandon
Conclusion- it's possible..
295/55r15 on a 8" rally 5/7 drop
Plans are to purchase 10" rallys later and mount the MT on those. Put the 275/60 cooper cobras on the 8" wheel and purchase some skinnier, maybe shorter tires for up front.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Sweet! I am planning to run 295's on mine also. Ordinarily I'd say run the same size all around so you can rotate them, but if it's not a real DD, then who needs to rotate them, mine will probably dry rot before they wear.
mattyb
