208 Transfer case Whines? "Pitch changes when I grab the shifter"
Edlanta
North Georgia
Ed
Hello All,
I have a 1986 K10, 350 cu.in. TH350 trans and 3" lift. Just had my 208C transfer case overhauled because it was making noise. Bad bearings, cracked planetary gear etc... Now it whines as I drive down the road. When I grab the floor shift and move it slightly it changes pitch. Could this just be a linkage adjustment issue? Fluid level is good. Any ideas what may cause this?
Thanks!
Ed.
1979 c20
Rat
'Repaired' stuff shouldn't whine, especially with slight pressure on the shifter. Have your shop go on a test drive with you and explain it. That's where I would start, because the "fix" most likely starts with removing the recently repaired unit for inspection. Unfortunately.
As far as what is causing this, my thoughts drift towards bearing play allowing gears to mesh improperly. But I'm not the expert, that person is on the way shortly.
Edlanta
North Georgia
Ed
I'll have to run it back over to the shop. I have the front end apart and was hoping that someone else may have experienced it and was an easy fix. Nothing on this truck has been so far. Thanks for the reply! Ed.
dvdswan
Port Orchard, WA
Dave
Sounds like a bad bearing. Yes new bearings can be bad. Does it do it in 4HI or 4LO as well or is it a different sound? Since you are hearing it in 2HI, most likely its on the main output shaft.
Key thing, if it wasn't there before the repair and is now... something that was most likely touched by them. Any new dents in the driveline?
59840Surfer
Montana
Joe
Any noises in High2 range should be investigated since there's no pressure on the planetaries and they're just coasting really.
But the OP said that if he pushes on the shifter, the sound changes.
That's just wrong on many levels.
It's back-to-the-shop for your truck, I think. But first, check the fluid level -- and see if they forgot to put it in --- yeah --- it happens.
That's one reason why I like my transfer case --- no pump -- just seriously overfilled!
Edlanta
North Georgia
Ed
I have not tried any other gear but 2H. The whine was load and I just wanted to get home. The shop said to bring it back so that is what I'll do. Just hoping to get lucky if it was a linkage adjustment.
Thanks All!
Ed.
87R10_Cruising
