208 poping
fullbore
Washington
k20
208 popping
Hello, anyone ever had their np208 pop and bounce away from the trany while in 4wd? I noticed a loose nut tightened it up but it still does it....Any suggestions?
Thanks
Full bore
It moves? That sounds like no good at all. Does the entire case move like the trans/adapter/t-case bolts are loose? Or does the case itself flex?
fullbore
Washington
k20
When I engage 4wheel low or high and let it idle forward the truck surges and makes a pop thumping sound. So I jumped out with the truck rolling and could see the t case in one corner pulling away every rotation. Must be a broke gear or bent shaft in the t case...
Pull the front driveshaft and then see how it drives in 4hi. That will narrow it down to a t-case problem.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Front/rear tires the same height/brand? 208s are chain drive, you know how a motorcycle chain gets stretched and slips on the cogs, or rides on the cogs funny. Everything sits on rubber mounts so a little movement doesn't concern me much.
jabara572
ATL
There should never be any instance where the T/Case separates from the tranny under load... you either have loose bolts at the adapter or a broken case on the transfer case.
Villano
