205 very hard to shift
TheLastViking
Idaho Panhandle
'79
K10 shortbed on 1 tons
Huge amount of resistance when shifting. It's so hard that you can't feel it go into gear. I just got this truck, and haven't been able to crawl underneath it to see what the problem is due to inclement weather. I couldn't tell it it was in 2high, so to get it home, I had to pull the shifter all the way back into 4high, and disconnect the front driveshaft (due to a broken u-joint). Anything I should look for before getting to work?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Possible mismatched front and rear gears or tire height can make it hard to shift. Low fluid can also be a factor. Trying to get any transfer case out of 4wd on dry pavement and be a real bitch. Sometimes with mine I have to back up a few feet, while still rolling pop the trans in neutral and quickly smack the shifter to get it out of 4wd.
firebane
Calgary, AB
Curtis
Not sure where you live but if the temps are below freezing and the wrong oil is used in the transfer case it could cause horrible shifting too.
TheLastViking
Idaho Panhandle
'79
Just went out and screwed with it. Feels like the shift linkage is really tight. I'll start by taking the boot off and getting a good look.
Georgeb
Wisconsin
George
K10 Burb Z71
I was going to say. try to separate if it is where the lever pivots or if it has something to do with where the shafts come out of the case.
TheLastViking
Idaho Panhandle
'79
About 5 hours south of you. It was well below zero on the drive home. Heater wasn't working either. Made for a miserable ride.
The shifter pivot bolt may need cleaned/greased.
TheLastViking
Idaho Panhandle
'79
Thanks for the tips everyone. Lots of great info here, and a much friendlier crowd than the internet rangers on pirate4X4.
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
I have nothing to add beyond the suggestions previously mentioned. Just wanted to say welcome to the forum (insert pirate middle finger smiley here)! Just kidding...:cheers: Everybody here seems to be very nice and willing to help. I have thoroughly enjoyed this forum.
Let us know what you find out about your issue. Mine has been difficult to shift too. I just took my case out for a rebuild, which I have been planning on doing for quite some time. Found a little water in the case. It wasn't a lot of water, and I don't think it was causing any issues, but it was due for a rebuild. I am hoping a refresh will help with the shifting. New bearings and seals never hurt anybody either. This is what my case currently looks like. Yes, I am super OCD about laying my parts out and labeling them. But it does make the reassembly process a little easier for me.
Wow, clean and tidy! I also noticed your tools nicely set out on the bench. Those are good habits :cheers:
flynhigh88
