2012 Yukon 3rd row K5 seat swap bracket
FitfoCustoms
Gary
Blazer 2wd
If any of you are thinking about putting a newer seat in your K5, this is how I made my bracket. If I get a lot of interest, I will show more pictures in detail.
Material needed is 1x2 inch square tubing. About 15ft is what I bought.
1/2 solid bar or rod stock. I had to buy 10 ft.
A small sheet of 3/16 plate. 12x24 should be plenty.
(2) 1/2" cable clamps.
Cut two sections of 1x2 to 49". These will be your front and back. Cut four sections of 1x2 to 20". Cut two 3/16 plates 5"x6"(REAR) and two 7"x6"(FRONT). Drill a 1/2" hole in each front 3/16 plate for mounting purposes. I cut my plate larger, drilled the hole, lined it up with the frame, and then trimmed to fit. Weld the front, sides, and back together for the frame. 49" is your width and all work will be within that 49". Cut (10) 1" pieces from the 1x2 tubing for spacers. I took a 4 ft section of the 1/2" rod and put through the front hook on both seats and put them on top of the frame. I centered the seats, front to back and side to side. Place to two center 1x2 sections(20") approx. 2" inboard of each inboard seat hook and weld. I put a spacer 1/2" from the hooks on the front side of the seats on both side of each hook. Look at picture with seats installed to see. Mark the spacers and remove the seats. Weld the spacers. Cut the rod to fit the space between the spacers and weld. Put the seat back on bracket so that you can see where to put the rear spacers. Put another section of rod in the rear hooks and snap it into place on the seats. Line the spacers to where the rod touches the bracket. Mark the spacers and weld into place. Weld the rod on top of the rear spacers. I drilled two 1/2" holes in each rear plate, right where my factory seat hook was. I bought two 1/2" cable clamps and secured the rear. The front of my bracket is flush with the front of the cargo floor. If you make your seat bracket like this, you can still use your factory side panels. I will be making my own side panels to mount subs into. I know these pictures are not everything that you need, I just decided to write this because I was bored at work. If anyone wants more detail, just let me know. Merrick's Garage has another bracket but IMO, it requires more drilling and puts your head into the hard top. The Yukon seats can be removed in a couple of seconds. The bracket takes about 5 minutes to completely remove. You could possibly make this with less or thinner material but I tried to make as stout and as low as I could. I will be taking some plastic tape and putting it around each section of rod where the seat hooks ride. This should stop any noise coming from the seat while riding. Note: this will give you a small amount of storage under the seats.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
any pics with them installed in the truck? how does the width of the third row seat match up to the cab of our trucks?
FitfoCustoms
Gary
Blazer 2wd
Sorry. I will take some better ones today. Had some bad weather here over the weekend.
FitfoCustoms
Gary
Blazer 2wd
I have since, cleaned up the welds and put everything back in storage. The front of bracket is flush with the floor pan. I will make a panel to slip over the front with carpet and the same for the rear.
Tombo
Auburn, Al
Thomas
K5 Blazer
350 Vortec
Just built my brackets Tuesday for a 3rd row out an 07 Escalade. Done mine with 2x2x1/8 angle and 1/2 inch rod. Got the plans from Merricks. Drilling actually didn't take long at all with a drill press. Total time was about 1.5-2 hours to build them. In my case height won't be an issue. I may still end up coming up with something else to get it close as possible to the floor. I'll get a measurement to the bottom of the seat once I get them installed.
Progh89
Davis
Blazer
Hello do you happen to have the measurements from the front rod to the back of the rod ? Thanks
eskimomann209
Modesto
Marcus
That’s supposed to be a three seater?? jeeeez that’s a tight fit
80BrownK10
Greenwood, SC
Nate
Those third row Tahoe seats are only for two adults.
JoshuOne
