2" Lift and 33's
Moose Drool
Southern Oregon
K1500
I currently have a 4" unknown susp. lift with 33×12.5/15 tires. I would like to get a 2-2 1/2" quality susp. lift. Will I have issues with the 33's on the 2" lift?
Recommendations on the brand of lift?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
if the springs are not too soft of a rate and you aren't trying to set RTI records you should be fine.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I have 285/75-16 aka metric 33s and no lift on a 1 ton. my frame height difference would be compensated by your lift, so it probably evens out. even if my tires were a full inch taller, I'd be good.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Those 2" lift springs, pretty flat, flex like noodles.
Wheel width and backspacing will be the biggest determining factor. After that it will be the spring rate and then the terrain you drive on.
Moose Drool
Southern Oregon
K1500
Obviously no RTI comps or rock crawling , lol. Just mountain off roading and towing a trailer.
Would HD springs be a good alternative to help spring rate?
Rusty Nail
Rusty
350sbc
I used to run 33sx12 50s with a 2.5" lift. Springs in front blocks in the back and it was fine with a 15x8 aftermarket wheel.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I used to run 2" Tuff Country HD front springs which raised it 3" over stock then settled to around 2.5"-2.75". I had 3" blocks on the rear with 285/75R16 tires.
Wheels were steel 16x8 with 4.25"bs. No rubbing. Even ran chains on them in winter.
I ran the HD springs as I was using the truck to haul weight. Normally they say the HD springs are for a big block, diesel, or a heavy winch bumper.
Moose Drool
Southern Oregon
K1500
Right now I'm leaning to the Tuff Country 2" EZ Ride fronts and getting stock rear springs with an ORD shackle flip.
Thoughts?
77 K20
Montana
K20 5" lift
HT383 fuel injected
Using your existing rear springs or ordering new ones? If you buy new ones you might get more lift than you want. And the shackle flip will probably shift the centering of your rear tire in the wheel well.
EZ rides on the front are about the best riding aftermarket springs there are- without going to custom springs.
My 2.5" rear shackle flip with new springs turned out to be 5.5" of lift.
Moose Drool
Southern Oregon
K1500
I'm considering buying new OEM height 6 leaf replacements for the rear.
roundhouse
atlanta ga
justin
77,78,79,80 ?
I ran 33 with no lift with no problems
Now have 4” Alcan springs with 35’s
Might have some rubbing but if the tires don’t rub a little when you turn the wheels and hit a bump
That means you got room for bigger tires
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Depends on the bump... 33s can rub if you twist it up.
dcameron787
Toronto
Dave
k20
I ran 33’s with a 2” rough country lift. No issues at all. I ended up going to 35’s with a 4”/2” lift.
85Shortsquare
