2/4 drop level issue
BW The Kidd
Pennsylvania
Blaine
I installed a 2/4 McCaughys Maxtrax drop level suspension.
Kit came with no instructions, couldn’t find any online.
With never installing a lowering kit before we put the drop shackle in the rear of the leafs and now I’m starting to get a knot in my bed bottom.
would I be able to move the drop mounts to the front of the leafs and have more space? Or should I get a shorter shackle?
figured I’d ask before I go and remove leafs/overloads.
animal
Lee
c10 silverado
350ish
You probably need to trim the bed support where the shackle is hitting.
BW The Kidd
Pennsylvania
Blaine
Already did, it’s knocking a dent in the bed floor not the support.
eskimomann209
Modesto
Marcus
You can’t flip ends. Shorter shackle is your best option.
Pics help a lot. Let’s us see what you can’t explain.
animal
Lee
c10 silverado
350ish
Yeah like @eskimomann209 says. I think we need some pics. I've never seen the shackle hit the actual bed floor. Even with shackles and hangers in the back.
BW The Kidd
Pennsylvania
Blaine
This is the right rear side thats putting a knot into my bed bottom.
DB59
Toronto
Dave
apache/suburban
isnt that the front spring hanger? thats supposed to be on the front of the spring flipped the other way. its upside down. with the 4" drop its the stock rear hanger with the longer shackle, and replace the front spring hanger.
Bennyt
Surprise
Ben
This is correct. That's a upside front spring hangar.
Bennyt
Surprise
Ben
Rare, but they can hit with wood bedfloors. Probably not a lot of the combination of wood floor and drop shackles running around though.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
I've got the wood/drop combo. Had to cut the bed support away. Not a structural issue.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
56" long spring set don't need to cut the bed! :)
DBeck350
North Carolina
Darren
Couple plus sides to all this, 1) The ass end will be lower then the pic you posted so that will be cool. 2) You live and you learn from your mistakes. Trust me, If I had a dollar for all the **** I’ve put on backwards or upside down I’d have enough money to drive a different square every day of the week. So flip your bracket, bolt the bastard on the front and roll on.
rdaghoian1
