1995 Chevrolet Sudurban Carb Swap
jjester6000
Illinois
Jack
C1500
I am thinking of swapping the original 330k tbi unit for a Rochester 2jet Carburetor.
I have the carb and the intake, I am just wondering about a few things regarding the swap.
It has never really ran right with the TBI unit, so I want to just get rid of fuel injection all together
Back in July, I did in fact attempt to make a carb work on the existing intake using a homemade wooden adapter.
(My one blurry image)
It actually ran, but I could not get the intake to seal around the base, so it ran terrible.
Preston
Mechanicsville VA
Preston
I have read that you will need to change the intake and distributor and not sure about ecu and fuel pressure regulator carb doesn’t need as much pressure. I googled your question and got a lot of information there are carburetor gurus on the site that can help you better than me, good luck there is a kit to rebuild your throttle body, easy to do and a lot less expensive.
jjester6000
Illinois
Jack
C1500
I know, I am going to put an HEI Distributor despite the fact that it ran with the TBI one. I have the transmission part sorted all ready, all it needs is a sinewave from the distributor (With the right circuit, I could provide this signal with a points distributor) as well as a value from the throttle position sensor. Also, I know that I need a fuel pressure regulator.
I got the Carb and intake from a junkyard for about $20, and rebuilt it with a kit a friend had laying around. The only thing that I need to figure out is how to affix the TPS my carb, and how to get the rats nest out of my intake manifold (it probably sat outside for many years).
Preston
Mechanicsville VA
Preston
Good luck keep your progress updated, many others would like to follow,
TBSS GUY
