1991 steering column loose and ignition switch binding
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
Can a loose steering column cause the ignition switch to bind up? It's a 1991 suburban. Column is loose where it tilts.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
It's definitely possible. The actual ignition switch itself is further down the column, operated by a rod that is actuated by the keyed switch.
Georgeb
Wisconsin
George
K10 Burb Z71
Yes, it can. try a different position for the tilt and see if it changes the resistance.
referrich
