RacingTurtles
- Sep 26, 2017
- Pennsylvania
- Apu
- v1500 Geneva Edition
- 350 tbi
INTRO
Hello and thank you for clicking on this thread. My name is Apu (yup, get your jokes goin) and I've got this old gal. Shes a 1990 GMC Suburban Geneva edition. I made an introduction thread when I first got her. She's been running fine for some time, had no issues and even loaded her up and helped my gf and her dad move to their new house. The engine ran perfectly fine. I know that there are some wires disconnected at the lower interior side under the steering column. My rear high top brake light doesnt work, my interior hvac panel,radio, and electrical door locks do not operate. The window controller from the drivers side works and all windows operate normally. Other than that the truck operated normally.
It is a 1990 GMC Suburban V1500
5.7L gas engine with 4x4 Auto transmission
There are some extra electronics with the high top roof and interior lights. I do not see any other modifications besides what I have seen to be standard with the Geneva package.
My new job had me traveling back and forth to California so I haven't driven her much. She worked fine on September 2 when I had to make an emergency Vet visit for my dog. There were no issues driving her then. I had to fly out the next day and came back on September 6. There was no rain for those days I was gone and no one operated the vehicle.
PROBLEM
September 7 I tried to start the Suburban and no go. I inserted the key while it was in the off/lock position. Upon inserting the key, I heard the continuous beep/key in ignition reminder beep. I turned it forward to the run position. The gauges lit up/Check engine light/ dummy lights are on. Volt meter showed less than 12 volts
So my volt meter is setup to show 8 volts is the lower left tab,then the red area slightly above it, middle tab is 13 volts, and right tab is 18 volts. Normally it sits just below 13 at this point when the truck was working fine. Here is how it sits as I cycle through off, run, start.
Turn key to the start position, I hear one click and at this point no start and all power is lost. I cannot determine where the click is coming from. It was as if the key was not inserted and everything reverted back to the position it would be at if the key was in the off/lock position.
Removing the key and reinserting it in the off/lock position results in a faint continuous beep. moving to the run position, the voltmeter shows around 8 volts (needle moves up a little) . Move to start position and it doesn't do anything, no click this time. Repeating the process shows no electrical action.
DIAGNOSTICS
I referenced the FSM found at
http://www.1990suburban.com/repair_and_service_manuals/index.cfm
Section A Page 36 which is page 49/402 when using the PDF has a flow chart for start and charge.
I jacked up the vehicle to have easier access to the starter. I put a test light to the purple wire at the starter and showed no voltage(light not on) and the multimeter showed 0.6 mV while in the off position.
Now I had a helper turn the key and try to start it. Still showed 0 V and starter solenoid did not click.
Now step 5 says to test connector at ignition switch. This means I have to remove the lower column access panel, unplug the connector C209 and test it. Step 5 says if that C209 connector shows voltage that I need to replace the ignition switch which I hear is a pain in the ass. If it shows no voltage then I must replace the open at the RED(2) wires and fusible link at the junction block.
In an effort to save some time, I am asking if you have any suggestions on fixing this, preferably in a
faster method.
These wires have been accidentally yanked on and they fell out. They are for my Radio and Hvac I believe. When I first put a battery in the truck after taking delivery of it, the only thing that came on was the AC. Then I accidentally touched these wires and radio and HVAC wont come on. They only had hooks on them and by accidentally moving the wires they just became unhooked from whatever they were on. I taped them up and kept them out of the way because I can still start and drive the truck without them. There is one red wire up top connected to something on the fuse block. A lower left blue one, a lower middle red one with a female end, and a lower right blue one. I just taped them up as you can see.
UPDATE #1
Current status
I am now opening the column panel to test the C209 connector. I will report back once I have more details.
With the flowchart saying to repair the open at the red (2) wires, I would assume that wire is meant to show continuity whether it may be with the key in off or run position.
UPDATE #2
I tried to get to the C209 connector for the ignition switch. I couldn't even see it. I may have seen that metal mounting plate thats on the back of the ign switch but I could not find that damn connector. I only took off the front plate, I didn't drop the column or anything.
I verified that all things had battery voltage at the junction block.
For ***** and giggles, I hooked up my emergency jump starter/battery to the truck battery, set it to jump start mode, and it slowly cranked at first but started up and ran normally.
With the truck running normally, I noted it said battery was at 13 volts at the truck volt meter. I had my brother hook up the multimeter to the battery and pay attention to the voltage as I held the engine at different rpms to see what it did. At idle, multimeter showed 14-14.25 Volts. This is with no load on the engine.
Then we went to different rpms and it went anywhere from 13.8-15 volts from idle up to 5000 rpm
I repeated the same test as above except with turning on my daytime running lights, headlights, and all interior lights and fog lights in that sequence. Engine did not skip a beat and voltage stayed around 14-14.8 volts.
Now we moved the positive cable to the connection at the back of the alternator. I repeated the no load on engine test with different rpms and voltage stayed 14-14.8 volts.
Now we moved to this test except with load on the engine. It was the same sequence listed above but this time, I turned on the lights at 2000 rpm. There was a momentary drop in rpm and the check engine light came on. After a few seconds the CEL went away. Still at 2000 rpm, we went to 3000 rpm. Daytime lights, headlights and once I started the interior lights, my brother said there was another drop in voltage and some more momentary hesitation.
Turned off all load. Took it to 4000 rpm. Did the headlights and my brother said it dropped to 10 volts and engine just died. At this point we are back at square one.
I hooked up the jump starter and there is nothing when I turn the key.
Geneva suburban by , on FlickrIt is a 1990 GMC Suburban V1500
PROBLEM
Geneva Suburban by , on FlickrTurn key to the start position, I hear one click and at this point no start and all power is lost. I cannot determine where the click is coming from. It was as if the key was not inserted and everything reverted back to the position it would be at if the key was in the off/lock position.
DIAGNOSTICS
faster method.
Geneva Suburban by , on FlickrThese wires have been accidentally yanked on and they fell out. They are for my Radio and Hvac I believe. When I first put a battery in the truck after taking delivery of it, the only thing that came on was the AC. Then I accidentally touched these wires and radio and HVAC wont come on. They only had hooks on them and by accidentally moving the wires they just became unhooked from whatever they were on. I taped them up and kept them out of the way because I can still start and drive the truck without them. There is one red wire up top connected to something on the fuse block. A lower left blue one, a lower middle red one with a female end, and a lower right blue one. I just taped them up as you can see.
UPDATE #1
Current status
UPDATE #2
