1990 Suburban Square Body Fuel Pump Replacement
Bright Idea
Scappoos, OR
V 2500 Suburbans
I have a 1990 suburban (square body ) that I need to remove and replace the in tank fuel pump. I am considering an access panel in the floor of the bed. it looks as though this is possible but a bit tight due to the support member spacing. The pump is centered between supports but the two line connections are under a support by a little bit. Has anyone made the change out using this method rather than dropping the tank? I am not concerned about reinstalling the cut out. this is an old work rig and would always be covered by the bed mat. I have seen many you tube videos of making access thru the truck bed but not specifically a square body suburban.
KilgoreTrout
Pennsylvania
Dylan
350ci
Man, that burb's gonna be full of holes by the time he's done with it. :D
Bright Idea
Scappoos, OR
V 2500 Suburbans
looks like I hit the create post button 3 times, sorry about that. I will reinstall the cut out with some tabs and sealant. It will be under the bed mat so not concerned about that just dont want to cut it if I am not going to be able to accomplish the replacement.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
A friend of mine replaced the pump on his ‘90 burb through an access hole, so yes, it can be done.
Bright Idea
Scappoos, OR
V 2500 Suburbans
Thank You that is the answer to my question.
3dbello
