1990 Suburban 350 TBI Fuel Pump
Bright Idea
Scappoos, OR
V 2500 Suburbans
The fuel pump (in tank ) has failed at about 170,000 miles and am going to replace. Many options out there. Any brands that are truly ahead of the rest in function and reliability out of the box? Any in particular to stay away from ? Thanks for the input.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Avoid Airtex like the plague. Delphi and AC Delco have their versions on the market, but I tried the Spectra assembly, and I’ve been happy with it, no problems from either pump or sender. I installed it two years ago. Just doing the pump, it might be best to do AC Delco, and that’s probably what I’d do if I’m not pinching pennies. I’m starting to feel like the Delco name isn’t what it used to be because some of their stuff I’ve bought over the past few years didn’t hold up like it should have. I know the Delphi mechanical pumps but can’t speak to their electric models.
idahovette
Weiser Idaho
Perry
K20-K10
Used a Delphi in my 02 4.3 C1500 SWB. Best price with a lifetime warranty from NAPA
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
CSFJ
I too have used the Delphi pump in an '88 half ton. I have no complaints. Worked perfectly the last 3-4 years that I had that truck.
Preston
Mechanicsville VA
Preston
Welcome to GMSB from Virginia
4WDKC
Southern Florida
Kacy
if you have any plans to increase performance use a delco/delphi pump from a tpi camaro or 96+ vortec truck.
Bright Idea
Scappoos, OR
V 2500 Suburbans
Thanks for the help. Assuming the fuel guage is working, is replacing just the pump and sleeve a good option ? or is it best to replace the entire assembly. I am thinking that there are likely things that will help determine that when the assembly is pulled ?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
At the very least, replace the strainer sock if you don’t buy a whole new assembly. If this is a vehicle that’s been driven it’s whole life, it’ll look alright, but the level sender will eventually succumb to wear and tear. If it sat for any protracted period of time, it won’t look so good, and when that happens, I say it’s best to roll the dice and replace everything (even the tank if it’s full of rust and/or the baffling is crumbling).
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Buy a Delphi from Napa. Stay away from AC/Delco fuel pumps they have crappy quality control. Delphi is a better made pump even though it is also made in China like the AC/Delco pumps. I put a Delphi in my 87 V-20's d/s tank going on a year ago and it is working great. Don't forget to replace your fuel filter too.
Clayton
Sent from my LM-V350 using Tapatalk
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
I replaced everything on my 87 V-20's d/s tank including the fuel lines. I only want to take the bed loose once.
Clayton
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Definitely. I have a drop hitch and shield to fight but still. No thanks. Good to know the Delphi is working for you. The Spectra has also done impressively.
PapaBear8486
