1988 v30 454 dump body lift advice
Usmczo6
New york
Alan
V30
Hello all, I have the truck stated above, I was looking if anybody on here can recommend a suspension or block style lift kit lift kit, your experiences and preference on brand, I would like to be in the 4-in area, I'm not looking for the best quality or most expensive, I just need something that's going to be able to handle the load of a dump truck for yard use and give the clearance for bigger tires, tire size advice would be appreciated as well,
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Don't see why you need anything? Dual wheels can't be very wide or they will "squat" with a load rub together and blow out. A yard of dirt is only around 2000 pounds, depending on moisture. You can haul that in one of these old half tons.
Craig 85
Nashville, TN
454/TH-400/NP205
Remember K30 frames are 2" taller than 1/2 & 3/4 tons. My 3" lift on my K30 works out to be a 5" lift compared to my last K15 with a 4" lift. I'm running Tuff Country 3" HD springs in front and a Fabtech #FTSBK3 3" block in back. My tires on both trucks are 33's.
@Lu Blunt has a lifted K30 DRW. He might be able to help.
K15 4" lift
K30 3" Lift
Usmczo6
New york
Alan
V30
I would like to lift this truck so it's visually appealing, I'm not looking to take it off road, occasionally I will haul some roofing materials or item for something of that nature, I'm sure there's a 4-in lift out there that would be perfect for this truck and would allow me to run a taller skinny tire
SirRobyn0
Rob
Also keep in mind that increasing the over height of your tires has the same effect as shortening the gears in the rear end ie. it will make it more highway geared. If this is hauler I would not change it for visual reasons.
75Monza
Colville, Washington
K30, K20, K20
Another thing to think of is your plow if you still plan on using it. Will need to lower it the same that you lift the truck. Sometimes you can get away with moving mount to the bottom hole on front brackets (if it's that style), but the plow angle is then different to road surface and tends to rip rocks out of the ground instead of bouncing over when you hit a submerged one, lol. Will also have to tighten up spring tension or it will lay over faster.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
235/ 85 R 16, is the tallest skinny tire I've ever seen edit to add in a 16. As wide as I would want on a dually.... Smidge taller than a 7.50 / 16.
Lu Blunt
Rye, CO
Luke
350ci
I lifted my dually k30 with 2” HD springs in the front and ORD 2” shackle flip in the rear. That way you can keep you rear leaf springs. It does make the rear most overload bracket to far from the leafs to be used but hasn’t caused me any problems. The hd front springs are made for big block/winch bumper applications and I’ve found them to handle weight well. 2” lift gives more ground/wheel clearance and keeps original payload. At 2” in the front you won’t have to lengthen drive shafts or add a steering correction
https://www.offroaddesign.com/suspension/suspension-lift-systems/73-87-chevy/k30.html
235/85r16 is the biggest tire you can run on a dually rear without spacers. Any bigger and they will rub when loaded. A lot of guys run 265/75r16 on the front and 4 235/85r16 on the rear. If you have the narrow 14 bolt rear you might run into leaf spring clearance issues trying to run a bigger tire.
Dooley
North Coast
RW
V30
Don't lift the truck.
I would never use blocks on a work truck.
Buy 255/85-16's next time you "retire" the truck.
They do not require spacers.
Been running them for years.
88SQDRW
