1987 wipers only work on hi
Dano93
America
Have replaced the switch and module also the motor
hatzie
k20
Do they park or just stop when you switch them off?
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Dano93
America
Thank you for your help , hatze they just stop where they are when i turn it to low or any other point than hi
Dano93
America
After testing and research someone had installed a newer 7 wire switch so I when I replaced the switch I did the same thing not having the part number. I have the 5 wire switch on order . Also found out GM has discontinued this part
Triv
South Jersey
Joe
k10 Silverado
check your grounds and connections. I had that issue for awhile. I now use electrical connection cleaner and dielectric grease often.
nathanjohnson85
