1987 V10 6.0 LS swap
putt2014
Turbeville SC
Frank
What advice do yall have for a 6.0 to a 1987 4x4 swap? Which 6.0 is the best for the swap? What kits or Accessories are needed. I want it to look factory and for the ac and all the gauges to work. Any parts numbers would be very appreciated. Thanks yall
dougbert
5535 feet in Utah Mountains
doug
K1500/nv4500/np241c/33x12.50x16/4.10 Gears 14BFF
5.3L - 2002 Silverado, rebuilt top end, long tube headers
If you are willing to search through my spreadsheet for various parts you can look at the file at dropbox
https://www.dropbox.com/s/jiesm7cdbfhb7p8/1984 K1500 with 5.3L Parts costs.xls?dl=0
It lists part numbers that I acquired for my build (whose thread is in my signature).
the LS 6.0 would fit just like a 5.3L into the mounts.
I used Dirty Dingo, though others will work.
I upgraded my fuel pump inside a 1987 side tank for 1984 K1500
hope it helps some
dougbert
87scotty
Central il
Andrew
V20
5.7 for now
Honestly not a fan of the 6.0 GPA has one in his truck and had to replace it at 140k and my gpas no hot rodder and maintenances it well! Heard of a few having problems I do love the 5.3 seen many 300k plus
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
One anecdote does not truth make. The 6.0L is just as reliable as the 5.3L. In my search for my 6.0L, I came across several in work vans with upwards of 350K. Not one of example either, tons of them.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
99-00 some have iron heads that kind of suck, and all have a long crank flange that requires them to be bolted to a 4l80e.
putt2014
Turbeville SC
Frank
Any recommendations on a donor 6.0. What year model for a swap
yevgenievich
Viktor
sad
very sad
less sad
or older transmissions(th350/th400/700r4 etc...)
throttle out
Michigan
Sam
5.3 LS
Just got my 87 V10 SWB back on the road with 5.3 LS power! lt1swap.com was a priceless resource along with DOUGBERTS thread you should have zero issues getting it done!!! This has been done a few times and there are many resources to help you along.
My truck feels like it lost 1000 pounds and is much more efficient.
Good luck!
Ls85c10man
