1986 C10 No Lowbeams - Highbeams OK
CATXTraveler
Dallas
I have a 1986 C10
Everything worked perfect (although no left indicator- but maybe that’s a separate issue)
Went to pull out the dimmer switch and no low beams. Clicked on high beams and all four headlights turn on.
I am getting power to the red wire to the dimmer switch and the yellow wire is getting power as well.
What should I be looking for next- I don’t want to just throw parts at it.
Thanks in advance.
Rickf
Grafton NH
1974, 1954 & a 1937
I have a 1986 C10
Thanks in advance.
I am confused, Everything worked, then you pulled the switch? Why?
Are you getting power at the low beam bulb? Unlikely but possible that both burnt out at the same time.
CATXTraveler
Dallas
I mean pull out the switch to turn the headlights on.
Which wire color would have power for the low beams?
CATXTraveler
Dallas
It does not appear I'm getting any power to the low beam lights. Only when the highbeams are turned on. Would this be indicative of a bad dimmer switch?
CATXTraveler
Dallas
Got the new headlight switch in, and it doesn't seem to have done the trick.
I was able to figure out the blinker issue so that's resolved.
For the headlights, there is no power going to the tan wire. When I click on the highbeams, the green wire is illuminating.
I tried tracing the tan wire back into the cab, but I can't work out where it's coming from to get to the headlights.
Could anyone help better describe the path of the tan headlight wire so I can keep trying to see where the disconnect is? Does it run all the way up the column to the highbeam selector/ turn indicator switch?
CATXTraveler
Dallas
For anyone with the same problem- it was the high beam/low beam switch located on the steering column (what they call a dimmer switch not to be confused like I was with the switch that actually dims the gauges). Will be ordering a new one.
tnahaus
