zieg85
- Oct 28, 2012
- Brighton, IL
- Carl
- C20
- 7.4L
Asking $200 for it. Oil pan to intake manifold including distributor. Has a flywheel (manual trans) Not included is the carb, sensors or anything emission wise. It has header type exhaust manifolds. The outer starter bolt hole was messed up by the previous owner and will need repaired before use. The engine ran perfect the 200 miles homes but has been sitting for 3 years or so. I will include the engine frame mounts and y-pipe, radiator/hoses and fan shroud if you need it. I calculated 17 mpg on that 200 mile trip. Located 50 miles SE of Chicago in Hebron, IN 46341
