1984 C20 7.4L/454 Factory Spec Upper Radiator Hose with Brass 4 ROW OEM Radiator
MatrixFab
NorCal
Daniel
C/K 20
Does anyone have a part number or vender that has an OEM 454cid factory style upper hose? All of the hoses listed on sites like RA and alike have a molded hose with the same end dimensions. 1.25".
My OEM Radiator has a larger Inlet than 1.25". The 1.25" dia fits the Thermostat housing but not the Radiator inlet. (Help) !
nvrenuf
Mobile, Al.
Is this the original radiator to the truck you referenced or a swap?
MatrixFab
NorCal
Daniel
C/K 20
OEM, Factory Installed
nvrenuf
Mobile, Al.
Ok, just being clear that it wasn’t like my blazer - factory radiator but from a different truck.
I have a factory 4 row 6.2 diesel radiator hooked to a 454, I had to have a radiator shop change the upper hose neck to fit the gas motor hose.
WFO
Texas Panhandle
MatrixFab
NorCal
Daniel
C/K 20
Thanks for the Reply's. I will check out the hose as mentioned. This site "Rocks"!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
“Heck Yeah!”
Craig 85
Nashville, TN
454/TH-400/NP205
I used a Napa NBH 8365. Their picture looks the same as Gates and has the same dimensions. Here's the radiator in my '85 for reference.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
on mine i just use en pluming reducer to fit my small LS hose! ;)
MAXMAN
WENATCHEE,WA
JERRY
V3500
OEM part #14029236. Might be able to use that for reference.
Danny Bordelon
so. cal
Danny
suburban R2500
i own a 91 R2500 Suburban 454 , replaced it with a alum rad with 2 elect fans. the upper rad hose has been replaced with something close but not the right fit. the hose took off at a 45 deg. to connect with the neck on the motor. i wanted the hose to fit close to the rad so i purchased a 90 deg. neoprene elbow then cut the long end shorter to make it fit close, add a aluminium straight connector for the first turn, then the Napa rad hose 90 deg. was cut off to the length needed to make the 2nd 90 deg line-up straight towards the motor. this also allowed me to clock the hose into the angle. my hose had 2 90's along with a 20 to 45 deg drop from top of rad to motor. if you dont have the right hose you can make a better fitting one.
ruggedly
