1982 Suburban Dimmer Switch and Headlights
KS2506
SW Kansas
James
K1500 Suburban
First, Thanks to all of you for your help in answering my problems with this old beast. Latest is the dimmer switch. It is on the floor. When I would try to dim the lights, they would go out. Press it again and only the dims came on. Press again and lights out. Got a new switch from LMC, part Number 36-0620 and a connector #36-0581. Made sure I wired the connector to the factory wires like the old switch.. Yellow on top, green on bottom and gray on top. Now I do not have any lights. Where did I go wrong? Also, would like some suggestions for improved headlights. Thanks, James.
KS2506
SW Kansas
James
K1500 Suburban
Hey, It dawned on me the switch has to be grounded. Got lights. Any suggestions for improved lighting? Thanks.
My go-to headlights are the Sylvania Xtra Vision lights that can be found at many parts stores. They are only a few bucks more than the standard lights, but they work well.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The dimmer switch doesn’t need a ground. The yellow wire supplies power from the headlight switch, the dimmer switches that power, light green is high beam, tan (I think) will be low beam.
KS2506
SW Kansas
James
K1500 Suburban
Thanks for the reply, great info, will copy this for future reference. James.
waterboy1234
