One looks like a short foot and one looks like a long foot. However, my quick research says that the narrow one is likely for the 700r4 and the th350 uses the wider one because of shaft length reasons. The bolt pattern should be the same presumably, the reason for the adapter offset/stuff is probably to retain the same crossmember design and keep things simple since th350 only used 2 years with np208You must be registered for see images attachYou must be registered for see images attach
One is wider than the other. Both have same height.
