schnid72
- Jan 13, 2013
- fallon, nv
- Nick
- k10
I have a 79 c10 with a factory 454. The engine was replaced back in 2014, by the owner before me, with the same peanut port 454 that it originally came with. Motor has performer intake, Holley 750, and headers. My question is on the timing, the manual I have says it should be at 4 degrees BTDC at idle (without the vacuum hooked up) this seems low. I have set the current timing to 13 initial and 34 total (both without vacuum) , I am wondering if this is to much? The motor seems to like it, It does not ping or anything. What do you think about the current set up? also why the heck would they have it set a 4 degrees BTDC? I have looked at a bunch of info and I cant seem to come up with why it would be set so low. the current set up seems to be pretty common (13/34) what do you think??
