1977 C10 not getting fuel
Drewthedew2013
minnesota
Drew
C10 Heavy-Half
350ci
Yup, it turned out to be the fuel tank selector valve. I bypassed it like you stated above; it ran perfect. From there I ordered a new valve, put it in and the truck ran like it should and had good fuel flow. Never been better. Thanks again!!
chengny
You're welcome, but no thanks really necessary. Just being able to help - and keep another one of these great trucks running is good enough for me.
gpmorgan
Tupelo Ms.
greg
Glad you got it running. Do you think the selector valve was stopped up, stuck between the tanks, or sucking air??
Drewthedew2013
minnesota
Drew
C10 Heavy-Half
350ci
I think it was stuck between the tanks.
Good job figuring out the problem fellas! :High 5:
Chevy-1986
Mo
Carmen
No fuel
Just found my problem with not getting fuel after replacing all fuel lines, three fuel pumps and a lot if sitting beside the road for 15 to 20 mins at a time! Anyways long story shorter, thought I was having a vapor locking problem but I also have an older almost worn out 305. After everything else had been replaced pulled the pump push rod and lobe on cam is completely worn out. Can't even hardly push pump. New motor it is. Was wanting 454 anyways. Here's my chance!
mattyb
