1976-87 dual tank harness available!
gmachinz
Harnessworx Inc
Iowa
Jabin
This LSx spec'd dual tank kit is going out tonight for a member in NM! I needed to finish drafting his harness diagram schematic for future troubleshooting and/or mods. On kits which significantly deviate from stock I design and include a color coded diagram using my graphics program-another benefit you don't get from the big harness companies! Then again, they don't offer what I do anyway!
I'm a long ways off from needing something like this, but maybe you can answer some questions for me. I've got a '79 K30 with dual tanks (older style switch and valve) that I would like to run dual TBI units on. I want to keep the original dash switch if possible. My only idea was to run a frame mounted pump, ahead of the selector valve... which I don't think the pump would like. Is there something that could be done, so I could run in-tank pumps and keep everything else appearing as original?
gmachinz
Harnessworx Inc
Iowa
Jabin
For ease of plumbing AND looking stock, I'd suggest since you want to go TBI anyway, swap out your tanks and fuel lines for a set from an 87 Silverado. It's all nearly a direct swap for you. I'd suggest using an 87 fuel tank dash switch in place of your existing one too. If you use the harness kit I have available, it will all work on your truck-you just need to handle the actual fuel component swap stuff then-my harness would be plug n play at that point.
highdesertrange
kalifornia
mike
k30
do you have a web site? I enter harnessworx and get mostly wireworx and a bunch of crap. please don't tell me it's on the facey thing. highdesertranger
gmachinz
Harnessworx Inc
Iowa
Jabin
No....I don't have my website up just yet-I've been working mainly with forum members and the majority of my harness builds are custom variations of OEM style harnesses.
gmachinz
Harnessworx Inc
Iowa
Jabin
This is the correct switch to use with my LSx dual tank kit. It's on/on instead of momentary/momentary.
ehernandez
