1973 e-brake from cab to frame
frankenstein66
doylestown PA
frank
yeah I'm new. ok so I have a 10\73 c10 that I wrecked when I was around 20 yrs old I swapped a 1977 c10 frame under the cab and put the truck together then it sat for years. recently I started working on it and got it on the road. I just took at apart to correct some issues that needed addressing. so I must have cut a riveted on bracket off of the 73 -74 frame that mounts the brake cable from the cab to the frame because something was different and I don't remember what. I welded it to the bottom of the 77 frame (hack) so now I want to see if I can make it correct for 1973-74. what I'm asking for are pictures of the inside and outside of the frame rails where the e-brake cable runs through or the cab mount, because I have no idea anymore it was 17 yrs ago. thank you I hope I can be a good help to you all in return.
redneckgames
