1973-87 Hood
jspringston1
Missouri
Justin
Hey guys I have a hood that is bowed up where the hood meets the fenders. Is there anyway i could fix it? Thanks!
Skweegle89
Oklahoma
Where are you at in MO? I have 2 hoods about an hour north of Joplin.
Swims350
Logan WV
none
lmc has a hood brace kit it's what you need even another stock hood is gonna bow over time.
firebane
Calgary, AB
Curtis
Once its bowed its done for and nothing can really fix it. You need a new hood and then add a good solid 1/8" or 3/8" flat bar to the bottom to prevent it from happening again.
Swims350
Logan WV
none
I don't see why our 76 bowed all the time we just pushed it back flat, if we had aded the braces it woul dhave fixed it since it woul dhave held it down flat.
Skweegle89
Oklahoma
I live in monett
**** your close. The hoods are in Nevada. I will be up next month. I can let you know when if that's what you want to do.
Skweegle89
Oklahoma
Wait a sec. 73 hoods aren't the same as the late 80s models are they? You don't have the wiper cowl piece between the hood and windshield. Will an 85 hood fit your 73?
Swims350
Logan WV
none
NO 73-80 and then 81-87 can't swap unless you do the entire front clip
Skweegle89
Oklahoma
Sorry man. I tried.
Skweegle89
Oklahoma
There is surely a scrap yard in Joplin that will have one.
Lastwords
Lindsay
Mark
I bent the hood on my regal. Forgot the magnetic tray when I closed the hood. Put a 2x4 at the front and carefully bent it back. You'll still need the braces so it stays straight. It won't be perfect but if it's a work truck it's cheaper than a new hood.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
Hey guys I have a hood that is bowed up where the hood meets the fendera. Is there anyway i could fix it? Thanks!
The hoods on 73-80 trucks at some point bend/bow when the hinges get stiffened over time. The hoods are designed to bend in that area in the event of a front end collision. I know there are brace kits for them, but my question is how safe are they. I myself would just be on the look out for another GM hood in good shape, and get new or lube up the original hinges really good, and maintain them.
Just my thoughts from articles that I've read in the past.
MannyDantyla
Lawrence, KS
Danny
sbc350/sm365/np205
Hey do you still have those hoods?? I need one and you're not far from me at all
(edit) nevermind, should have read the whole thread first, lol
beetlejuice01
