PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- Suburban k10, bonanza k10, c30 C&C, c10, gmc 1/2ton
- 350, 350, 350, 350, 350
The leaf spring perches measure almost perfect, I will have to change one shock mount. I haven't searched yet but I'm sure I can find a conversion ujoint easily, and I feel like my driveshaft will be okay length wise still. I'm not worried about the gear ratios as of right now.
Now the problem I have is brake lines, I believe the 1970 axle has a smaller diameter brake line and for sure smaller/different size fittings.
My question is, are there some adapters available to go from one size fitting to another or would I be able to do some switching on wheel cylinders, or do some aftermarket solution?
