12v Cummins wiring question
marks86
Latham, NY
Mark
12v Cummins
First off I understand a 12v cummins needs 12v to the starter and 12v to the fuel and thats pretty much it.
my questions is when I removed the old 6.2 harness it attachs right to the fuseblock(the block is three pieces) the main piece of the block is that harness, so my question is how can I remove all this useless wiring but yet still have the fuseblock put together...if this makes any sense at all
the harness Im removing has the sending unit power wiring and windshield wiper motor in it so I will have to remove those put IDK how too
marks86
Latham, NY
Mark
12v Cummins
let me makes this alittle easier to understand
there is a huge wiring harness on the firewall that goes to the fuseblock, I want to remove it but I need to use three wiring that are in it, how do I do this
IIRC, the main block mounts to the firewall and includes the interior harness, then there's the two parts under the hood. One half is the lighting harness, the other is engine related. I'd guess that you can just remove the unused wires from that one part of the junction and then put it back together.
marks86
Latham, NY
Mark
12v Cummins
whats IIRC mean
I've tried to remove the pins but there is like gel holding all them in
whats IIRC mean
If I Remember Correctly
You will probably have to heat up that goo and then there will still be a tiny little tab in there somewhere to release the wire/terminal. Most folks probably just cut the wire flush.
marks86
Latham, NY
Mark
12v Cummins
well I would like to add a few wires, can I find a blank one and just repin it?
Re-purpose some of the wires you wanted to get rid of?
marks86
Latham, NY
Mark
12v Cummins
I understand alittle better now, Im getting ready to do with in the next few days ill let u know
Snips71
