12V cummins swap
td87
CT
Trevor
V20
Alright well I have been wanting to do this swap for about 3 years now and am finally ready to do it. I want to drop a 12V turbocharged cummins in my 85 K30. Also has a 3" body lift if that helps for clearance. Front axle is Dana 60 and rear is the GM14 10.5...ex-military pickup with practically no miles on it. I took the 6.2 out and installed a 350tbi which runs great but theres just something about a cummins. I want to make this swap as much bolt on as I possibly can, and the least amount of welding.
I understand that there are so many threads about this swap all over the web but would like to start my own here on GMSB.
What trans and tcase am I best off with in this swap? Also what are the best bolt on motor mounts and crossmembers that I can purchase? If anyone has any answers or any positive input for me I would appreciate it...Thanks
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
td87
CT
Trevor
V20
Awesome!! Exactly what I was looking for because I really don't want this truck to be as high as it once was. Thanks alot!
td87
CT
Trevor
V20
Just ordered woohoo. And for transmission and transfer case. What are you running if I may ask?
td87
CT
Trevor
V20
What 12v would I be better off with...the 1st or 2nd gen?
td87
CT
Trevor
V20
Ok I found a 96 dodge 3500 with the 12v. Truck has 150,000 +\-. It is a rust bucket but the motor is good and the trans leaks and is weak. He's asking 2300. What do you guys think?
TexasOutlaw87Cummins
santee
cody
k 30
5.9 cummins
Good deal but get that engine and a NV4500 os the tranny combo I wish I had used
td87
CT
Trevor
V20
Well Ive just been gathering parts and whatnot, I ended up buying a 94 3500 with 89k miles. It has an auto trans and is also 4wheeldrive. I think Im just gonna run the automatic transmission for now and maybe down the road, switch it out. I have a GM NP205 and an NP208. Will these bolt up to the dodge tranny??
JohnT
