10 bolt front
roy c
long island
roy
do they have a front excel posi ? like the posi rears have so when you apply gas the front tires grab where needed. with out doing that thumping you get when you cut the steering to tight on dry ground in 4 wheel drive ?
Thanks Roy
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Not really, you're going to have driveline binding if you drive in 4 wheel anything on dry pavement or hard pack, and may even have something break. Always try to avoid driving in 4 wheel drive on pavement unless it is raining or snowing/ice.
roy c
long island
roy
thanks, On my 87 sub when i lock the front hubs do both front wheels lock sort of like a spool or do they spin independent of each other I remember last year pulling out
in the drive way 2+ feet of snow I could swear one tire was turning the other wasn't
Thanks Roy
Driver4r
Nebraska
Trevor
k10,c20
When both hubs are locked, the carrier is still open, if its factory.
roy c
long island
roy
what do I need to make them both turn when I lock them on the hub?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
What's your budget?
roy c
long island
roy
don't want to break the bank just want to know what it takes
crazy4offroad
Curt
K-10
350/SM465/NP205
10 bolt diffs are a dime a dozen a nut like me would weld the spiders to the side gears and if you want no binding leave the driver hub unlocked. Be aware with both fronts pulling full time steering is greatly diminished (worse than what you have now). It is also very stressful on parts, you're likely to snap stub shafts, hubs, or even the carrier itself. I would just drop in a Powertrax No-Slip limited slip drop-in and stay away from lockers, spools or welding gears.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I have an Eaton Truetrac in the front of mine. Still feels like an open differential, but will transfer power over to the tire with more traction. It has worked great for mud, snow, dirt, hill climbing. Wasn't too impressed for rock crawling- but don't do that often.
No clutches to wear out and no limited slip diff additive is needed.
$470 for my truck (4.10 gears, D44 front diff)
http://www.summitracing.com/parts/dtl-913a592/overview/
Application lookup chart:
http://www.eaton.com/ecm/groups/public/@pub/@eaton/@per/documents/content/ct_128302.pdf
nataca
vernal, ut
nathan
k10 scotsdale
When you lock the hubs you are just connecting the wheels to the axle(basically) the othe end of the axle is still in the carrier which most of the time trucks are going to have an open carrier up front. The locking hubs are only there to reduce the wear on parts not needed for 2wd
usar17
PA
K20 Silverado
TBI350/700r4/NP208
77 how is that on daily driving? I've always been afraid of random lockup. Keep buddy told my fronts should only ever be manual control locking to prevent random lock up if the hubs are locked. Does it limit your turning more then normal with locked hubs having that locking diff?
Ultimately front diff lock would be best in snow because you have the weight of the engine on the axle.
Sent from my SCH-I545 using Tapatalk
JOD26
