1 ton wheels on 1/2 ton truck?
waynew
Rocheport MO
Wayne
K1500
Vortec 327
I remember some mid 70's half ton 4x4's with 16 inch rims. I think the tires they ran were bias ply 6.50-16. These rims were probably only 5 inches wide so skinny skinny. I had a '76 3/4 ton that used 7.50-16's.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
The 31-10.50-15’s I’m running are a load range c. How heavy are you looking to go?
Craig 85
Nashville, TN
454/TH-400/NP205
My friend had a '71 C10 he got from his grandpa. Had stock 16" wheels, probably the same ones you're referring to.
waynew
Rocheport MO
Wayne
K1500
Vortec 327
The guys that ran those 6.50-16 bias ply tube type tires would get about 12k miles out of a set before they needed to be replaced. They also carried 2 spares with them as they had lots of flats. They were working out in the boonies of Wyoming so a long way from help.
Yep, they were available on 2wd's too. Also only 5 inches wide. They must have been very uncommon, I don't remember the last time I saw a set of them besides mine.
85 CUCV
Homer Alaska
Terry
CUCV M1009
6.2 l diesel
If I found a viable solution for the right price, I could always buy a couple steel wheels from the junk yard for the tires and then just switch them out when I go get wood..
The front isn't really an issue, just the rear...
But I thought the taller tires that 16s would allow might be nicer for winter driving when I gotta deal with snow..
85 CUCV
Homer Alaska
Terry
CUCV M1009
6.2 l diesel
Taller is good in the snow.
Just don't go to wide
Wide pushes too much snow when it gets deeper than a few inches.
85 CUCV
Homer Alaska
Terry
CUCV M1009
6.2 l diesel
Taller is better but not to wide. Wide pushes to much snow when it's deeper than a few inches.
As for breaking axles you can do that at any speed. If a tire slips then grabs when you have power in it u- joints and axles are weak in your truck. You have 10 bolt differentials I think. Not GMs best.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Oh that depends... I prefer wide tires as long as I have enough power to spin them. Takes more skill and throttle to drive wide tires.
Skinny tires and anti-lock brakes best for civilians... but not for 'driver'. IMO.
85 CUCV
Homer Alaska
Terry
CUCV M1009
6.2 l diesel
True that. I like challenge and Finesse though sometimes plain brute power is the only answer.
Here where most of my local wheeing is on our beach along Kachemak Bay and Cook Inlet.
Rocks, sand and winter ice with Tides to answer to thrown in.
mrburitto
Casa Grande, AZ
Cody
K20 Cheyenne Camper Special, C30 Crew Cab Dualy
Looks like fun! Rhino/Raptor liner must be like gold out there...
85 CUCV
Homer Alaska
Terry
CUCV M1009
6.2 l diesel
This is what you have left after you lose a battle with the he tides.
The beach took this one about 6 months ago.
Not being properly prepared is Fatal for any truck caught by one
77 K20
Montana
K20 5" lift
HT383 fuel injected
Instead of focusing on load rating (C, E...) look at how many pounds they can handle. All load range C tires do NOT have the same rating on how much weight they can handle. The bigger the tire, the more weight it can handle. Here is just some examples from BFG KO2 All Terrains... (all tires load range C)
LT235/75R15: 1,985 lbs
30X9.50R15: 1,990 lbs
31X10.50R15: 2,270 lbs
32X11.50R15: 2,535 lbs
33X10.50R15: 2,600 lbs
Figure all the ones listed above would fit on the rear of your truck. Also with these tires there is some sidewall tread to help protect it against punctures (and to help prevent getting stuck)
Have you ever weighed the truck with a full load of wood on it?
aultinator
