1 piece floor pan?
Square head
Ontario Canada
Ken
Does anyone know of a 1 piece replacement floor pan for an 87 GMC K20?
I looked on different sites and can't find one. It seems the after market is lagging behind on the 1981 - 1987 c & k models in more than 1 area. I would like a 1 piece pan so as to eliminate visible seams from underneath the truck.
Sprockmonster
Connecticut
Logan
I've only noticed that there were half pans on lmc. I purchased them and they go from about two inches up the hump(this is a high-hump cab) and they go to the inner footwell, so they have a half inch lip towards the outside of the panel near the doors.
Just curious, what is your reason for having no visible seams from underneath?
TopFuel1
Pennsylvania
Jack
As Sprockmonster mentioned, most sheet metal suppliers will have 2 or 4-piece floorpans for the majority of repairs due to manufacturing costs and potential fitment issues. I liked LMC's floorpans for my 1979 3/4 ton and they fit well with some minor tweaking. I will suggest that you buy all of your sheet metal from the same place. I made the mistake of buying kickpans and inner rocker panels from a local supplier and ended up doing more work to make everything fit.
Scott Vincent
Sierra Vista, AZ
Scott
350 B30over
joseph916
