PeteJr
- Jan 12, 2021
- NW MS
- Jim
- GMC Sierra Classic 1500
Sam, thanks for the comments.@PeteJr Jim, what is your trucks drop stance? That is perfect. Call me an old soul but I would never want a slammed stance but just right.
I just "wanted" to level it, since most trucks are a little higher in the rear normally. Started with 2 1/2" dropped spindles, new stock front and rear springs. Also, 2" dropped spring hangers in the rear and 2" lower rear shackles.
This combination actually raised the front up an 1" and that wasn't what I wanted.
I got a set of 2" lower front springs and that gave it the look you see now.
It has stock shocks and the fronts are close to bottoming out. Probably will change those to lowered shocks.
Trial and error.......... Hope this helps !
