Front indicators alternating when headlights on
I AM CORNHOLIO
Australia
Derek
Hi Everyone,
I have an issue with headlights, indicators and marker lights.
When the headlights/parklights are off, the indicator and side marker flash in unison.
When the headlight or parklight circuit is powered, the indicator and side marker flash alternately. Both sides do the same, so it does indicate the correct direction.
Is this a normal function? The truck (my prfile pic) is a 73C10 with (I'm guessing) an 83 onwards front and interior
Cheers
Dleslie212
Phoenix
Dustin
5.7L 350
Hi Everyone,
Cheers
Mine does the same, after a complete wiring harness replacement. It's just the way it works
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
One of the cool features I still to this day enjoy watching. :cool:
They are functioning correctly. :waytogo:
Bloodhound1981
MA
Rusty
C-10
Hi Everyone,
Cheers
As stated, it is correct. It has to do with the fact that the side marker lights don't have their own ground, they are powered through the front turn signal bulbs. So when the parking lights are on, and the turn signal is activated, the side marker light goes out when the front turn signal activates, hence the alternating action.
I AM CORNHOLIO
Australia
Derek
I wonder if I give those side markers their own ground? Have you or anyone ever done it?
Bloodhound1981
MA
Rusty
C-10
What would be the point? They are ungrounded by design so that they flash on and off.
Oldbear42
Linden, Alberta, Canada
Shaine
C20 LWB Scottsdale
I set up the front signal lights on my Goldwing (when I replaced the side reflector with an LED light) the same way because I liked it on my old 89 GMC.
C30vet
