Need a little guidance (suburban floor rail)
cbrown5385
Mass
Corey
Suburban 1500
I have a 1990 2wd burb and one of the rails in the rear with the body mount it’s roached. What is or what have guys done to repair this. Aside from taking the whole body off the frame.
Thanks in advance!
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I imagine they're similar to the pickup box supports. Closest thing you'll get most likely.
fast 99
Spokane, Washington
Gosh, some areas of the country rust is horrible. Most of the time vehicles in the NW only have that kind of rust if it was imported from another area. We have some problems with it but usually not that bad.
gmbellew
Kansas city
glen
suburban 1500
i live in the Midwest and this is why I Krown my suburban every fall. best $150 I spend each year on it.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Never knew of a product like this so I looked it up. Pretty cool
gmbellew
Kansas city
glen
suburban 1500
if you have a Krown installer within driving distance, it seems to be a good investment each year. my burb gets driven in all weather, and they use a lot of salt when it snows. so far so good on keeping rust away for the last 6 years.
The only proper way to fix that is to pull the body off, drill out what spot welds you can/cut the rest off, encapsulate the rust and weld back in a new cross sill. You'll either need to find a parts truck to pull one off of or modify a truck bed cross sill to work.
Looking at all the flaking, you're probably going to need that body mount as well and possibly some frame work. Personally, I'd be looking to buy a cleaner 'burb and swap any of your good stuff on it
TBSS GUY
